digitaleos
I just received my U2 last week, right away I had to bend up the the four tabs in the tailcap for the clickie to work, problem fixed, that is until last night when I had my U2 on level 6 for about 1 minute, it started to flicker then went to level 1, Now if I rotate the selector ring back to level 1 and then back up to level 6 it works for a little while longer then goes back to level 1. The first thing I did was check the batteries, they were fine. Then, I checked the tailcap, it seemed fine. I even took the tailcap off and used a paperclip to make connection between negative battery terminal and the body of the flashlight, it would do the same thing level 6 for awhile then flicker to level 1. Has anybody else had this same problem, by the way it does this on primary 123's and 18650's.
Chris
Chris
