Ty_Bower said:"You probably shouldn't be swapping heads and bodies between the (L1,L2) and the (E1L,E2L,L4). If you do, you'll likely end up with a light that's in direct drive (no converter) or you have the output of one converter trying to drive the input of another. Either case is less than optimal."
https://www.candlepowerforums.com/posts/1388468&postcount=5
A runtime test of the L2P running off one NiMH AA (see post #6 of this thread) showed that the L2P runs brighter off one AA than the L1P does. The L2P provided very flat regulation at about 360 cd for about 80 minutes before crashing. The L1P ran at a lower level (240-250 cd) for nearly 3 hours before falling off.MSI said:...And you won't get much light when running the L2 head on a much lower voltage that it is designed for, but it should not take any harm from it...
Ooooohh..........uh, never mind, then.........Valpo Hawkeye said:nerdgineer
They aren't talking about Fenix!!!!
