Acebeam
Results 1 to 20 of 20
Thread: anybody got a BCS Powerstik 8AA, I have questions
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    England, United Kingdom
    Thinking anybody got a BCS Powerstik 8AA, I have questions
    It comes with two types of bulbs an 500ma and a 900ma both are 3.6volts.
    they are supposed to be a special bulb, but they look similar to a standard PR type bulb that you find in a maglite.
    my question is, will a 3 cell maglite bulb be compatible as long as it`s under 900ma.
    here is a link, so that you know what i am talking about.
    http://www.flashlightreviews.com/rev..._powerstik.htm
    thankyou.
    John.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
    Banned AshA4's Avatar
    Oct 2005
    Western NY
    Default Re: anybody got a BCS Powerstik 8AA, I have questions
    I've got one and you can experiment with bulbs.
    I use a mag 3 cell bulb in it and it works fine.
    Not really sure why FLR states you MUST use the included bulbs for it to work properly, unless its to guarentee the listed runtimes.
    Jan 2006
    hello AshA4
    thanks for the good news, I was worried i would have to buy special bulbs.
    what do you think of the adapter, is it worth the money.
    have you used yours much.
    thanks
    John.
    Oct 2005
    Western NY
    For what it's intended for I suppose it's a good product. I think it would be more suitable for poweroutages/emergency use with the regulation.
    Let's face it, using a 3 cell mag bulb in a 2 cell body doesn't really get me excited even if it is regulated.
    I put mine in one of those "classic" style lights from Wallyworld and put it in a drawer.
    Apr 2004
    BuckSnort
    Its a good unit. Fivemega once offered potted strion bulbs that made it very bright.
    Favortie Light: A2-BK-WH
    Jan 2006
    any idea of the maximum current it can handle at 3.6volts without blowing up.
    accutually i am more into run time than brightness.
    I wonder what is the lowest ma a PR 3.6volt bulb comes in.
    thanks.
    John.
    Jun 2005
    Mostly Staying Inside
    The Powerstick is rated 2A max. The Strion bulb, which is close to that max rating, sure makes it throw far, but the spot will be very small.
    "Constantly talking isn't necessarily communicating."
    Jan 2006
    hello MSI.
    how do you know that the max rating is 2amp, is it in the instructions or have you had a peek at the regulator.
    I am still waiting for mine to be delivered.
    regards
    John.
    Jun 2005
    Quote Originally Posted by TinderBox (UK)
    Fivemega said so in his sale thread. I think I may have read it in the instruction sheet as well, but can't find that now.
    Jan 2006
    thanks MSI, a lot to read.
    john.
    Jan 2006
    does anybody know if it will work with nimh batterys.
    as on zinc-carbon, alkaline and lithium are mentioned on the website.
    thankyou.
    John.
    Flashaholic* Lurveleven's Avatar
    Dec 2004
    Bergen, Norway
    Yes it will.
    Sigbjoern
    Jan 2006
    I wonder if it would be possible to recharge the batteries without having to remove them from the adaptor, it would be quite a time saver.
    thankyou.
    John.
    Dec 2004
    Bergen, Norway
    You will have to remove the batteries for charging.
    Sigbjoern
    Jan 2006
    I thought if i connect my smart charger to the + end of the adaptor and the - on the springs at the bottom battery`s
    It looks like the electronic are at the bottom under the springs.
    I don`t have my adaptor yet so i cant tell for certain, are you certain.
    regards.
    John.
    Dec 2004
    Bergen, Norway
    If you bypass the regulator then you may be able to do it yes. Be aware that the batteries are in a 2p x 4s setup.
    Sigbjoern
    Jan 2006
    both sets of batterys will just charge in parallel.
    you must have one of these adaptor Sigbjoern.
    thanks for your help
    John.
    turbodog's Avatar
    Jun 2003
    Southern USA
    I was the one who originally found this device. And I can confirm the 2A max bulb amps is correct.
    It's not terribly bright, but since it IS regulated the light is really white.
    If you're looking for extra bulbs I would find one that actually has 3.6v stamped on the bulb. I think the halogen mag bulbs (3 cell) are rated at 3.6v.
    It's a nice unit, and if I were going to use a 2d light exclusively I would consider it a must have.
    This is your life, and it's ending one minute at a time.
    Be prepared for the truth.
    Jan 2006
    hello turbodog do you have anymore information on the 3.6volt halogen mag bulbs.
    thankyou.
    John.
    PS. the closest i can find are 4.0v halogen.
    Dec 2004
    Bergen, Norway
    Yes I have, but I don't know where it is right now (can only find the box). It is probably having a party with the lost M2 reflectors
    Sigbjoern
