Imalent
Results 1 to 10 of 10
Thread: Amount of light loss through Surefire F04 diffuser?
    Oct 2005
    Ontario, Canada
    Default Amount of light loss through Surefire F04 diffuser?
    The flashlight geek in me wants to know:
    How much light is lost if I stick my F04 diffuser on my E1L or U60GT?
    I'd say it's quite a lot but how much is it? 40%? more?
    Anybody with a light measuring system want to give this a go?
    Flashaholic* chesterqw's Avatar
    May 2005
    singapore,jurong
    Default Re: Amount of light loss through Surefire F04 diffuser?
    40%!?!
    man i don't know how much it is.. but it should be less then 10%.
    if killing was legal, i would have killed countless number of people...
    Flashaholic* John N's Avatar
    Oct 2001
    Seattle
    Dunno how much, but you can get an idea of how it will look in this post.
    -john
    On a single level light like the Streamlight TL-2 LED with an intense hot spot which renders it unsuitable for close range tasks the Surefire diffuser makes a big improvement.
    I never worried about how much light was "lost", I was always just thankfull for the reduced glare. I use the FM34 Medium Angle Beamshaper on a Scorpion LED for one of my BOB lights. IMO choosing a multilevel light would greatly reduce the need for add ons like diffusers. Backsplash and glare are just as easily solved by using less lumens to begin with.
    Paladin
    Jun 2005
    Mostly Staying Inside
    Based on ceiling bounce test I would guesstimate it to 15%, but it was only when I was switching very fast between them I could see the difference, so it does not matter much.
    "Constantly talking isn't necessarily communicating."
    Flashaholic* Long John's Avatar
    Mar 2006
    Spain, near Cadiz
    An alternative for a diffuser could be a white reflective beacon.
    I own a yellow one and I'm very inspired.
    I have the subjective impression, it added brightness.
    Take a look here:
    http://www.candlepowerforums.com/vb/...d.php?t=133336
    It's a very useful addition for every light with a max headdiameter of 3cm.
    Best regards
    ____
    Tom
    *Flashaholic* Size15's's Avatar
    Aug 2000
    Kettering, England
    Quote Originally Posted by chesterqw
    40%!?!
    Correct.
    The F04 and FMx4 BeamDiffusers (aka BeamShapers) use a highly specialised (and expensive) LSD® Light Shaping Diffuser featuring holographically recorded, randomized surface relief stuctures that enable High Transmission Efficiency (up to 92%), and Controlled Angular Distribution, while providing high quality Homogenised Light. The material is a 'shatter-proof' polycarbonate.
    The BeamDiffusers increase the area illuminated by the beam by a factor of 25.
    Jul 2004
    USA
    Damn Al,
    There were more three-dollar words in that reply than a lawyer's "summation" to a jury. I had to get my dictionary offen the peg in the outhouse and bring it into the house just to cifer it. 10% would have been my guess also, but you plum dressed it up pertier.
    Flashdark sends, edumicated.
    A flashdark is a device that projects a black circle upon (thereby obscuring) anything which is visually offensive. Surefire: E1e/KL1(2), E2L, E2e, E2C/P-61, KL2, KL3(1,2v3), KL4, L1-RD(1), L1-WH(1,2), L2(1), L4, L5, L6, G2, C2, U2, K2, M2, C3, M3, M3T, M6. Milkyspit: ML-1, MilkMite. Photon: Freedoms(WH/RD/TQ).
    May 2005
    AZ, USA
    Size15 was spot on.
    Just did some quick, crude measurements with an F04.
    2AA MiniMag w/ stock incan: 90% (transmission)
    Longbow Micra: 91+%
    F04 was fairly clean, but not perfect, sooooo.
    As usual, ymmv.
    Oct 2005
    Ontario, Canada
    so it's about 90%.....thanks guys
