I am trying to determine what type of battery pack I need to drive my Tri-Lux. I will be using a Fatman driver with UWOK LuxIII's.
Here are my calculations from the Fatman tech page:
Power Output = 3 (LED) * 3.51 (low Vf for UWOK) * 1000 (max current)
Power Output = 3 (LED) * 3.75 (high Vf for UWOK) * 1000 (max current)
Power Output Range = 10530 - 11250
Power Input = Power Output / Efficiency
Assume 90% efficiency
Power Input Range = 11700 - 12500
Current Input = Power Input / Battery Voltage
With a 7.2V battery pack
Current Input Range = 1625-1736mAh
With a 8.4V battery pack
Current Input Range = 1392-1488mAh
Assume 11.1V battery pack
Current Input Range = 1054 - 1126mAh
Here are my questions:
Are my numbers correct?
What runtime can I expect?
What battery pack value will increase runtime (voltage or current)?
Why is this so confusing ?
