I do NOT trust online storage.
Maybe as a backup, for certain files,
but it wouldnt be good for GBs of data, and its not all that reliable.
I have had a few photos come up missing from my site, hosts can be hacked, etc.
I looked in to the Terastations also.
They are definitely the best bang for your buck, as far as $ per GB of Raid5.
But, you get what you pay for.
They are easy to setup and use.
And should be reliable, seeing how they can be set to RAID 5.
The main complaint I read about them was their slow speeds.
I think that is due to them being Software RAID.
The Teraststion sure would have been more in my budget,
but I went all out, and bought an Infrant ReadyNAS Nv.
http://www.infrant.com/products/products_details.php?name=ReadyNAS NV
Infrant invented their own type of RAID, RAID X
The best part about RAID X, is there is no need to format the RAID Array,
You can start out with 2 drive, and it automatically mirrors the drive,
add a 3rd drive, and reboot it, it automatically sets up RAID X on it, and your space doubles. (3 x 100GB drives = 100GB of actual redundant RAID storage space)
Later on, you can add a 4th drive, and your space triples. (4 x 100GB drives = 300GB)
Just like RAID 5, one drive is used for parity.
Then after you have all 4 100GB drives in, later on down the road, you can actually replace those drives with larger drives.
Just replace one drive at a time, and the system re-allocated the space.
Most other RAID 5 systems can do this, at least not as easy.
The Infrant also has a TON of other added administration features,
and has a great built in backup utility.
The USB ports are also compatible with just about any USB device, including hubs.
The Terastation only sees Printers and External Hard Drives. (and no, those external USB drives can NOT be part of the RAID 5 array)
But, all this comes at a price,
the 1TB Terastation will run you about $600
The Infrant ReadyNAS NV cost me $609...... with no drives.
~John
