davidefromitaly
i'm really undecided for what kind of reflector use in the luxeon K2, i need one that have a flood spot and large spill, i had think to use also a modded surefire P60 reflector cause is also LOP... otherwise?
i need also a deep reflector with a tight spill and a high lux reading, but with a diameter under the 33mm. i have try the IMS 27mm and isn't bad but if exist something with a higher quality...
