EvilLithiumMan
I like to think of this mod as a "Poor Man's Orb Raw". (It's either that or some version of "Death Wish").
Having a nice Lux III UWAJ star from 4sevens and knowing how easy the Nuwai QIII is to mod. I decided to disble the QIII's converter circuit and see what would happen if I connected the star directly to an unprotected 800mA RCR123 cell:
I also (correctly) figured that my two stage would be used more at the low setting than the current sucking high setting, so I bumped up the low setting with a second 10 ohm resistor:
The results range from incredible brightness to "I won't be surprised if this poor, unprotected cell blows up in my face." Here are the current / voltage / power readings I obtained:
2.2A Vf=3.5V 7.7W
1.9A Vf=3.4V 6.4W
1.6A Vf=3.3V 5.3W
1.3A Vf=3.2V 4.2W
140mA Vf=2.97V .415W (5 ohm in the two stage switch)
I'm more concerned about the unprotected cell failing (exploding?) than the emitter failing. The retaining ring is quite tight against the star, and there is thermal compound on the star and the aluminum heat sink ring of the QIII. The light warms up quickly at full power, indicating good thermal transfer.
Here's a beam shot. The QIII is pulling 1.9A (6.4W) and the Orb Raw cell is hot off the charger:
You can see how intense the beam is from the QIII. At 1.3A (4.2W), the QIII appears equal to the Orb Raw. Unaccounted for is the QIII's reflector - it is a heavy stiple vs. the smooth of the Orb. I wish there was a smooth reflector for the QIII as I am pretty sure that would result in a 15 to 20% gain in illumination.
Note the Vf of the UWAJ at 140ma, 2.97V, effectively making it a UWAG at that level:
Next on my QIII plate - I have a couple of pretty impressive Lux V WX0S stars. I'd like to put one in a QIII, powered with a RCR123 and driven with a Badboy 500ma converter. Oh wait, 6V Vf at 500ma is only 3 watts. That's going to be boring now
ELM
2.2A Vf=3.5V 7.7W
1.9A Vf=3.4V 6.4W
1.6A Vf=3.3V 5.3W
1.3A Vf=3.2V 4.2W
ELM
