bobhere said:what can i do if i add a a19 to a 9p or if i add 2 a19s to a 6p? as far as light bulbs heads and the power of course
Same here, C3/A19/P91 on AW's 2x17670s. Love it!powernoodle said:I've done this, which happens to be right in front of me: 6P + A19 + A19 + P91 lamp + two Pila 168S batteries. Great light, lots of output, throwy and floody, and rechargeable. Gets the Powernoodle seal of approval.
peace
Omega Man said:Same here, C3/A19/P91 on AW's 2x17670s. Love it!
Mad1 said:You could call it a 12P
You will need this bub.
G&P G12 12 volt
http://www.lighthound.com/sales/gp_flashlight_bulbs.htm
From what I can tell Surefire doesn't make a 12volt the the C or P series.
No need to double click for me, but something funny has happened twice with the setup. When the 17670s go in hot off the charger, and the light it turned on, it goes off after about 10 seconds. This happens twice in a row, then will stay on and behave normally until the cells are dry.SunStar said:Do you have to double click to fire that P91?
I don't know if its my lamp or cells but I can't get the AW 17500's or the 17670's to light the P91 on a single click.
glockboy said:Add KT turbo head and MN60, MN61 bulb, 4 cr-123. You got the SF M4.
Omega Man said:No need to double click for me, but something funny has happened twice with the setup. When the 17670s go in hot off the charger, and the light it turned on, it goes off after about 10 seconds. This happens twice in a row, then will stay on and behave normally until the cells are dry.
BTW, I'm using the new AW cells, with the nice silver/black with red band at positive end, wrapping.
bobhere said:what is better the Pila 168S, AW's 17670s, 17500's, or 18650, i want max power and of course i want max lumes but dont want to run 20 mins i would like to keep the burn at 60 mins roughly as i sit with the 6p im ordering the a19 after i play with that i will add 2x a19's what is biggest bulb i can put in?
SunStar said:I don't know if this helps but here is a few data points for your reference.
(2) AW 17500 / MN-15 (125 lumens) = 60 - 62 minutes of runtime;
(2) AW 17500 / MN-16 (225 lumens) = 22 - 24 minutes of runtime;
(2) AW 17670 / MN-16 (225 lumens) = 40 - 42 minutes of runtime;
(2) PILA 600S / MN-16 (225 lumens) = 42 - 43 minutes of runtime.
I would expect the P90 (105 lum) to perform similarly to the MN-15 and the P91 (200 lum) to perform similarly to the MN-16 with each battery set. The 18650's will give you the best performance but they will not fit your 60/A19 tube without boring.
NotRegulated said:Forget the boring. Purchase a 2x18650 tube with C to C threads. Keep any eye out on CPF.
I have a Tranquillitybase tube with an M2 head, P91 and two protected AW 18650 batteries as a stand-alone dedicated 18650 light. It works identical to a 9P with A19 and P91 running on two protected AW 17670's but runtime is longer. However, what you give up is versatility. With the Surefire tubes, you can use CR123's if you rechargables die. Can't do that with the larger tube.
