Sold/Expired SOLD: Budget Ti heads for the McR20
TranquillityBase
Here are two heads that are too short for the standard window. I've had them in my 'what to do with those' cabinet for a while now. My math was off by the thickness of the o-ring, give or take.:rant:
I forget that I have windows that I purchased in March of 2005, for some of my Q-3's...They are thinner windows, but they are the correct diameter. The thinner window will allow proper gaps at the bezel ring and cell tube to LE. The heads will work with the thicker windows for the A19, PD, HDS, A2...but it's BS...the gaps are too wide, and the cell tube to head o-ring probably isn't going to do its job properly.
With the thinner window, everything is fine...the LE E-can is flush with end of the head, and the gaps at both the bezel and cell tube to head are good...I took a close photo, so you can see if you agree before purchasing one.
I will sell these with a window and window o-ring. You must provide the reflector and LE.
I have one window that is in the paper envelope, and two that are wrapped in tissue...My Shoppe order sheet shows that I ordered AR and standard mineral glass...I don't know which is which? You may choose one or the other...I think the tissue wrapped windows are the AR, but I really don't know??? I only have one that came in the little envelope.
The first 'I'll take it' post will have the choice of head design, they are both the same except for the exterior design.
$75 delivered
Thanks for looking,
TB
Morelite
Central PA
Re: FS: Budget Ti heads for the McR20
I'll Take one
The one shown on the light.
MorpheusT1
Norway
Nice snag guys :)
I especially like the one standing.
and Scott nice work as always ;)
Benny
Morelite
Central PA
TranquillityBase said:
Which head pattern would you like, and which window?
TB
Russ can choose the window he wants, I have several different thickness' to choose from in my stock.
:paypal: has been sent.
Thanks Scott
TranquillityBase
Morelite said:
I'll Take one
Just so there's no confusion. The one shown on the light in the first two photos (top and middle), or the one shown on the light in the third or last photo?
BladeZealot
Brandon, MS.
I only see the bottom pic...?? The other two are just X's.
paypal sent. The lens in the paper envelope, please.
Thanks
Russ
Morelite
Central PA
I only see one pic too. I want the one with the same pattern as your tubes.
TranquillityBase
Hopefully Dwayne's computer loaded all three photos?
Russ, I will send you the paper envelope window, and the 'Twisted Croc.' head pattern, unless Dwayne tells me differently.
TB
TranquillityBase
TB
Got it...that explains why Russ asked me for a side view of the other one.
I will PM the other photo Russ.
TB
MorpheusT1
Norway
Only one pic showing here too,
Try to load the pictures again.
I had some trouble with Imageshack earlier today.
And after reloading it worked fine.
Benny
Morelite
Central PA
TB
