InfidelCastro
Banned
I was thinking of picking up a 3 cell Maglight and an upgrade module, I was wondering if the heatsinking problem that degrades output has been solved?
Since the only intent was to sell a conversion module, thermostatic power reduction, rather than heatsinking, was chosen.
TinderBox (UK) said:has their been any decent CPF devised heat sinking ideas for the MAG C and D.
KDOG3 said:I was just thinking about that! I'm suprised someones hasn't attatched a copper band the emitter and spiraled it out to finally make contact with the head wall.
I have three Mags that need something like that, and if we're talking about a $10 part, I'd probably need more than 3! I'd say there's a definite market for a cleverly-shaped piece of aluminum.InfidelCastro said:... I bet if somebody make some they would sell like hotcakes. ...
InfidelCastro said:That would be a good idea if somebody made one. I think it would help the incan bulbs too somewhat.
I don't know if it would work though, because I think that part might need to be electrically isolated from the tube.
will said:The new style switches are basically 2 halves that are molded. The old stlye had the tube I made as a separate piece. There is a lot of machining on the part that I made. In addition to the tube with a flange on the end, there is a slot, which you can see. there is also a square groove on the inside, like a keyway, that holds a flat spring that makes the negative electrical connection to the bulb.
I would not guess what that would cost to make for the newer style switches, but ceretainly a lot more that $10.
nelstomlinson said:Will, what you made looks as if it would work a lot better than the replacement nut that I was proposing, but it might cost more, too, and be a bit more bother to install. Do you have any idea whether it would make sense to try that replacement nut idea that I proposed just a little way up the thread? Do you think that it could be made fairly cheaply?
I like your replacement bulbholder, but I'm reluctant to spend loads of money and time upgrading the Mags, which are not _that_ great to begin with. At some point, it makes more sense to just buy a better light.
Nels
