Incandescent keyring lights?
Paul_in_Maryland
Maryland, USA
I'm looking for a keyring light--one that can use 1XAAA lithium, 1XAA lithium, or 1X14500 cell. Many cool keyring lights are short, slim, and powerful. But they're all LEDs. Are there any comparable incans?
I used to use the Underwater Kinetics 2xAAA side-by-side, but it would be nice to have something brighter.
I'd consider 1x123A or 1x17500 cell.
I really don't want to have to build one from scratch with Aleph-caliber parts.
InfidelCastro
Banned
USA
I had a Solitaire on my keyring for many years if that helps. (I know it doesn't :D )
They still make those old squeeze lights that looked like a mini bar of soap?
Yea, I wouldn't mind something that ran on lithiums that was about the size of a solitaire, but had the output of a minimag...
paulr
There are some incans but they're less bright than leds. If you're willing to use 1x123 try something like a Firefly, Fenix P1, etc. If you want a lightweight 1x123 incan, you could try a Tekna Splashlite, but it's nowhere near as bright as a Luxeon light. In fact with the stock #222 bulb it's about as bright as a CMG Infinity Ultra-G (I did a direct comparison). With a K222 krypton bulb it's somewhat brighter.
Ritch
Central Europe
I would recommend the UK 2AAA too.
Next stage would be the SF E1e, imo. Highest quality, good throw.
big mike 27
I know you aren't looking for LEDs, but I have one someone gave me for xmas from Brookstone a few years ago and this thing has taken a beating and is decently bright. Probably ~$10 and I can't reccomend it enough.
Paul_in_Maryland
Maryland, USA
I may have to settle for a wimpy, 11-lumen light like the UK 2xAAA. I'll also check out the E1e.
What about a UK 2AA with two 14500 cells and a lamp from a 4xAA? Except I can't see how I'd get 2 lithium-ions to add up to the correct voltage (4.8V?).
Mikeg23
Indiana
Would just one 14xx0 power the 4AA lamp?
pedalinbob
Michigan
The Princeton Tec Blast is pretty bright, but might be a bit chunky for the keychain. The beam is decent, and the price is right.
I think it is similar to the little UK in output.
That Digilight looks interesting.
Phaserburn
Connecticut, USA
Would a PT Tec 20 be too big? Solid light, water proof at depth, and I've run mine on 2x14500 cells driving a Mag 5 or 6 cell bulb.
paulr
Tec 20 is large for a pocket light and completely oversized for a keyring. Same with UK 2AA though its head is smaller than the Tec 20. PT Blast is a little bit large for a keyring; similarly the UK 2AAA though it's smaller than the Blast. The Blast uses a reflector-lamp assembly with a minimag-like bi-pin bulb soldered to a PC board. I guess you could replace that with a higher voltage bulb and put in two 10440 li ion cells. Is there any particular reason you want an incan instead of a led? I think leds have completely defeated incans for low powered lights (= anything you can reasonably put on a keyring).
With 1x17500 and a Strion or similar bulb, you could beat most leds, but I think a 17500 light isn't really a keyring light. If you'll accept lights that large, maybe you want to think about a 2x123 light, e.g. Surefire E2e, or UK 2L with the 4 watt lamp.
Paul_in_Maryland
Maryland, USA
Exactly. I want something with a bezel slimmer than 1.25 inches to eliminate the telltale bulge.
I've found that when I shine an LED light outside, I can't easily discern what I'm looking at.
I am, in fact, looking into a 1x17500 body + Surefire E head. I'll check out the UK 2L, though if I must use AAs, I strongly prefer lithiums, and I think that any UK lamp will hotflash with lithiums.
Is there a hotwire Minimag 1AA or 1x14500?
Coop
Tilburg, the Netherlands (perfectly reachable by U
Ledean sells cutdown 1AA minimags here on CPF, Lighthound sells hotwirekits for 2xAA minimag running on 2x14500, change the bulb to a Strion bulb and use on 1x14500, et voila! 80 lumen from 1AA sized minimag... It might be pushing the li-ion cell a bit hard tho...
carrot
New York City
The Tektite Splashlite comes in xenon, 5mm LED, and Luxeon Star variations... The Xenon Splashlite is pretty cheap too. I thought I saw a review around here that says it's not bad...
paulr
The regular (incan) splashlite comes with a #222 screwbase bulb that's quite dim, as I mentioned. It's a nice little light, but I'd say to think of it as a "vintage" piece that's technology behind the times. You get more output AND more runtime from the led version.
I think the PT Blast bezel is less than 1.25", anyway I don't think it makes a significant pocket bulge. The UK 2L maybe makes a bit more bulge because it's a larger light, though the old version's max diameter is about the same. I have both lights and can try to measure the diameters later today if you want. The new UK 2L has a bezel shroud that makes the diameter larger, though I think you might be able to remove it. You get some backspill without it, but that never bothered me much.
I guess you could set up a 1AA minimag with a 14500 plus the hotwire socket/reflector and a Strion bulb. Or maybe you could mod a Surefire E1e to take that bulb, and power it with an RCR123A. A cut-down Streamlight TL2 would take the bulb directly, but might be a little larger than an E1e.
Paul_in_Maryland
Maryland, USA
Thanks, PaulR and others; these discussions have been fruitful.
It seems that the three high-output xenon 1x123A lights--Digililght T3 (30 lumens), Pelican M1 3310 (30 lumens), and Pentagonlight X1 (40 lumens), all have 1.25-inch bezels. For this reason, I'm going to rule them out as a keyring light. I will, however, buy the X1 to attach to one or both of my commuter bags. Of the three, it alone has a way to attach it to anything--in this case, a swivel clip.
Humble and dated though it may be, the Splashlite (0.75-inch head) emerges as the keyring winner! You can't beat the price or the size. Digilight's 1200XB (0.9 in. head) was runner-up, but there's no way to attach it. Yes, LEDs put it these xenons to shame. But once I go the LED route, there are so many great options, you're talking many hours of comparing! And LED beams leave me cold.
Most of the time, I'll have a Wolf Eyes 100-lumen 1x168A light in my pocket. The keyring light is for those few times when I don't.
