matrixshaman
I recently got a Luxeon V (I believe) LXHL-LRD5 bin T5SY dental blue LED. Being retired and with little cash flow now I am going to try the infamous 'self-dental' plan so I've gotten this LED to cure some dental stuff. Based on the bin code for this LED the 'S' is the Vf so it's listed as 5.91v to 6.39v. Since I'm still not real clear on how to drive an LED safely I'm asking for ideas on powering this LED. Based on the Vf I'm thinking I could direct drive it with two CR123's which are normally 3 volt or up to around 3.2 fresh out of the box. Would it be safe to do this or would the current drawn by the LED need to be limited with a circuit? I don't really care if this LED has a shortened life by exceeding it's limits a little bit as I won't be using it a lot but I just don't want to blow it up (very expensive Star). Any thoughts, help, suggestions much appreciated.
