I wanted to let current owners and future owners of the SF Kroma light know of some battery tests I've done with the Kroma-MS. The Kroma-MS, and I assume the regular Kroma, can operate normally with either a non-rechargeable CR123A pair of batteries or with the rechargeable RCR123A pair of batteries. The barrel of the Kroma body is not large enough to handle the popular 18650 rechargeable battery. The Kroma body is capable of fitting the rechargeable 17670 battery, but the operation of the Kroma is affected by this battery. Straight from the charger, the 17670 Sony Energytec battery reads 100% charge and 3.61 VDC under load on the Ansmann Energy-Check LCD battery tester. The ZTS MBT-MIL tester shows 100%, but does not display the load voltage. The Kroma-MS will operate the white LED under low power and high power mode normally, but when you switch to the other colored LEDs, i.e blue, red, IR, or yellow-green, the selected colored LEDs light up as well as the main white LED. This occurred in all switch positions for all the colors. This could be a potentially hazardous occurance, when you need to have only a covert red, IR or yellow-green LED lit.
I don't think this is a defect with the Kroma in any way, but rather something to do with the regulation circuit in the light. As a reference, two Energizer CR123A batteries stacked and measured on the Ansmann at the same time gave a reading of 100% and 4.99 VDC. I felt it was important to let all Kroma users know this, as in a tactical environment it may be important. Thanks, and stay safe!
