BruiseLee
My Lightwave 4000 has suddenly become very dim. So dim in fact that even with all 10 leds on you couldn't read a newspaper placed 1 inch away. Of course I checked the batteries with a multimeter, and each had over 1.5 volts. I changed the batteries just to be sure and put in new ones, same problem.
I cleaned all the contact surfaces of the flashlight and that didn't help either. The switch seems to be working fine, on and off is no problem. Any idea what the problem might be? All 10 leds do go on and are evenly lit, but the output level is pathetic. I never dropped the light, and it has no visible physical damage inside or out.
Bruise
Bruise
