What ohm resistor for E2L and L4 two stage tail cap?
Delta447
If you want to convert the L4 clickie tail cap into a two stage brightness tail cap that will work in both the L4 and the E2L, what ohm resistor would you recommend? It looks like something between 10 ohm and 22 ohm will work, but not sure what would be best for both lights. I just picked up the L1 and really like the two stage function, so I want to be able to do the same for my L4 and E2L. Thanks.
p.s. When is it a good time to admit that one has a light addiction problem?
Art Vandelay
I have the L4, E2L/E1L, and a two stage tailcap with 22, 30, and 60 ohm resistors. My guess is you would be happy with either the 22 or 30 ohm. I don't know if the 10 ohm resistor would be enough to keep them out of regulation.
