Re: Newbie... 4,000 hours battery for LED? You guys are great!
Chelsea378 said:
How do I figure out how long a light will work for with what type of battery?
Do I measure the amps?
That's a good first step, but you have to consider the current draw of your whole setup, not just the LED itself. For instance, if you have an LED with a resistor to limit the current through the LED - that resistor will be converting some of the electricity to heat, and that energy loss needs to be taken into account as well as what the LED itself uses.
These things can really surprise you, one way or the other. As someone has already mentioned in passing - the more slowly you drain a battery, the more energy you actually get out of it - and that can change your runtime calculations. For instance, a CR2032 coin cell is rated at about 200 milliAmp-hours; theoretically, that would run an LED at 20mA for 10 hours, or at 5mA for 40 hours - but I've had an LED running with useful brightness off of one of those cells for over 100 hours!
I don't know how efficient the circuitry in the PAL light is, but the closer your battery voltage is to what the LED requires (most white LEDs will light up at something under 3v, though most are rated to have a "forward voltage" of about 3.2-3.6) the less energy you have to waste with a simple resistor in order to properly drive the LED.
For example - to run an LED with a Vf of 3.2 volts at 20mA from a 4.5v source (say, 3 AA cells), you'd need a 68 ohm resistor. In this case, according to the calculator over at LuxeonStar.com, the LED would dissipate 61 milliwatts of power, the resistor 25mw.
To use a 9v source, you'd need a 300 ohm resistor - and the LED would put out 62 milliwatts - but the resistor would burn up 112mw - nearly twice as much as the LED itself!
Given your stated wish to have an LED run for 4000+ hours, you'd need to minimize energy waste, and avoid batteries that tend to self-discharge - unless there's some way to incorporate a solar panel or some such to recharge the cells.
Is there a particular reason you need a setup to run that long (nearly 6 months) unattended? If you could explain the purpose a bit more, people might be able to make more directly useful suggestions.
