JNewell said:Inova 24/7 does that also.
EngrPaul said:It takes what... a couple mA into a red LED a few tenths of a second every 5 seconds? Battery should last years in this mode. I've seen it in incand. at the store (Sears?) Why are none of our LED manufacturers doing this?
bitslammer said:Oh I completely misunderstood you. I thought you meant a light with a rescue beacon. You meant a light with a light so you can find the light. Yeah I'd go tritium for that I guess.
JNewell said:No, the 24/7 does have a "find me" blinker. If you turn the bezel halfway between any two clickstops it will blink the red LEDs once every 10 or 15 seconds or so.
EngrPaul said:That's great. How much does it cost and where does it come from?
I live near TMI, I should be able to get 20 years out of the tritium...
EngrPaul said:Is it a special action to put the flashlight in this mode, or is it automatic when you shut the light off?
And make sure you have several vials on there facing in all directions as the glow is quite weak and you'll have a pretty hard time finding the light if the tritium vial(s) is facing down.aceo07 said:As mentioned before, the HDS EDC U-series has the blinker/locator feature. Never had to really use it, but it's blinking just in case I do need it.
If you go with tritium, make sure it's stuck in an area where it won't break if it hits the ground.
