Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
It's well known to people who own various lights of both types that incandescents throw (ability to project a beam far away) better. If you do a ceiling bounce comparison between available Luxeon light and a incan light that throws the same, the Luxeon bright has substantially more output, meaning the for given output, it doesn't throw as well.
I think the reason is the size and the place of the light source. A filament is closer to a pinhead spherical point source and emits light in all directions, excluding obstruction by lamp base.
Luxeon LED is a small square that only emits light above the horizon line and I am guessing the beam is somewhat conical shaped.
Given a Luxeon and a incan lamp each producing exactly the same output, are they capable of producing the same throw if were to use a larger, different shaped reflector to adjust for larger light source and conical beam pattern of Luxeon?
