etc
It uses 3AA, which is what I wanted.
Is the 390 to 395 range good?
This large uv flashlight with 49 uv LEDs allows you to cover a much bigger area without losing the intensity of the UV light. The applications is perfect for inspection applications, security control, rodent contamination, hotel room inspection, and much more.
Emits 390 to 395 nanometer wavelength
49 UV LED allow to cover a larger area
Makes semen stains and other bodily fluids fluoresce!
Perfect for outside use such as hunting scorpions and minerals!
Water and shock resistant!
Perfect for Leak Detection!
Rugged, machined aluminum construction with knurled design!
http://cgi.ebay.com/Largest-49-UV-L...ryZ66954QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
