My wife's ARC-AAA developed a flicker. It's an older model (both the ARC and the wife, actually).
I cleaned all contacts and replaced the battery, the flicker didn't go away.
I soldered a wire to the (+) on the head and connected it to my bench power supply. I ran a wire from the metal thread of the head to the bench power supply, too. Now electrical contact should be perfect.
The head lit up, sinking 130mA at 1.3 V
After a few minutes, the LED started to flicker and current somewhere b/w 90 and 130 mA (a constant 1.3 V across the head).
Around half an hour later, still flickering, rather dim now, current ranging from 60 to 90 mA (still 1.3 V).
I read a bit on CPF where the crimp was mentioned as a possible cause to the symptom. The head of my light looks like not having been crimped or maybe not crimped much. Pix:
I connected one segment of the outer (circular) track of the PCB to the head's body using a tiny screwdriver. No change.
I connected the remaining segment to the head's body and this made the light come back to full brightness and 130mA current draw !
My first thought was adding some solder. At second thought, the head is made from aluminium, that won't accept any solder.
So I considered pressing the collar down some more with a screwdriver to improve contact b/w PCB and body. But wait - why not first upgrade the LED while the collar is not much crimped ?
At this point I have a few questions to the ARC-AAA experts of the forum:
1) Has the collar of my light been crimped correctly or can this be considered uncrimped ?
2) Is there any point in upgrading the LED of this old ARC AAA (while repairing it at the same time) or is this not a good idea ? Something like an incompatibility of the electronics with newer LEDs ?
3) If an upgrade is appropriate, where to order the brightest 5mm replacement LEDs and have them shipped to Europe ? I have doubt's that the ones I got from local EBAY are any better than the original LED.
4) Is simply crimping the head sufficient to achieve a reliable electrical connection b/w PCB and body ?
Any help greatly appreciated !
