Handlobraesing said:
You'll be amazed at Mag LED. 2AA LED is a lot brighter than Minimag you have and 3AA LED is even brighter.
There is no comparison between the Mag LED"s and the Fenix L1T and L1S.
- The Mag uses cheap type 2 annodizing
+ Fenix L1T uses Type 3 or Hard annodize which is the toughest type
- The mag uses a plastic lens that will scratch easily under real use
Quality lexan typical absorbs 15% of the light coming out of your light.
I'm not even sure mag uses lexan.
+ Fenix L1T uses Anti-reflective coating that maximizes the amount of light
from your LED. Around 99%
- The mag uses 2 or 3 AA cells
+ The Fenix L1's only use a single cell.
- The mag has only one level of output - when you're depleted, thats it.
+ The Fenix L1T puts out 10 lumens of constant output on low on plain
alkalines - runtime varies with brand. With Nimh and lithiums you'll 50-70%
more runtime. On high you get 2-3 hours.
I find that the low is too bright when I use it in the middle of the night.
It's enough to read at night
Here are some graphs for ya
And as Handlo so kindly pointed out in this
THREAD
mag does not cover LED burnout in their "limited lifetime warranty"
Fenix doesn't make such exclusions to their warranty. As a Fenix dealer I have pledged
to take care of whatever problems you may have.
I've done
warranty service for Fenix's that we're not even purchased from me.
I've been on CPF over two years and I'm committed to serve the cpf
community.
Handlo simply has a problem with me because He requested a Fenix for testing.
Without hesitation I graciously offered him a loaner. He requested a freebie. I refused. He then
decided against his so-called tests. Now he has a problem with me and
searches all the Fenix threads and trolls - one fenix thread was closed
because of him today.
Anyway, I'm compelled to post here to defend myself from his trolling. And
I feel the community deserves to know what is really going on.
