Put some tape on the lens. Use a small center punch and a shot filled fiberglass
hammer. A couple light taps and the lens will shatter. Use a small pick and pull
the lens out. Blow out the reflector and LED with compressed air. A few tiny
specks will remain but are not noticeable in the beam at all. Do not touch or
scrape the reflector. Use eye protection. When you hold the punch tap gently,
you don't want it to hit the reflector or the LED. I used an 8oz hammer and it
worked great. My lens was really stuck and all other methods failed. The light
was a U60GT.
was a U60GT.
