My OD Galdius arrived today as well. Slight rattle in the OLD STYLE tailcap, even though the s/n was 159xxM. All functions work perfectly! Package was the "carry handle" version, not the later square box. Cells dated 08-2015 FWIW. The newer style cap has some material machined away from where it meets the battery tube. The difference is very slight, and was done to prevent tolerances from stacking up and causing issues. The tailcaps that work out of the box should be good to go, rattle notwithstanding. The finish sure looks like HA to me, there are even slight color variations between the "parts" like with Surefire bezels/body/switches.
But the gods of luminosity were NOT smiling on me this day. The newly arrived OD Gladius has a bit of silver looking debris stuck to the underside of the front lens. The non-dissasemble bezel! So it will be winging it's way to Montana tommorow, where it will be quickly made right. Maybe I'll whine a wee bit about the tailcap rattle, since it will already be there...
Paladin
ps, wow, the Falcata 9 volt light feels heavy, even though it weighs almost the exact weight as my favored KL3/9P setup. Tailcap draw right at 1.25 amps, probably throwing a little over 100 lumens, no beam artifacts, the reflector has a fair amount of stippling. Tossed the rubber "wings" right in the junk box. happy to note it is a very sweet combo installed in the Modulock holster provided with the Gladius. the extra length makes pulling the light free very natural and easy.
