Black Majik
Hi guys,
I received an A2 from a board member, but I'm not really sure how it works since its a twisty.
When I put the batteries in, it feels as if the momentary on button doesn't work if I screw in the tailcap tightly all the way down. Am I suppose to leave it not screwed in all the way so that the button has room to move? Or is my tailcap broken?
Also, does the A2 come with a lock out function? If the light is a twisty, that means I twist the tailcap or the lamp to turn on the light permanently? If I screw it in all the way, first the LED comes on, then the incan comes on all the way.
If the tailcap is screwed in all the way, I can turn on and off the light if I tighten/loosen the lamp. This obviously doesn't sound right.
Am I suppose to leave a gap on the tailcap and not have it fully tightened all the way? That just seems weird, I cant help to think that it should be screwed in all the way and have the button still work. If its screwed on all the way then the button sticks/wont move.
Otherwise, it seems like quite a nice light.
Please advise, thanks.
-Richard
-Richard
