tibim
Everyone knows about the issue with the magleds regulating down to less output due to heating up. I just purchased a 3D mag w/ magled yesterday and was noticing there is quite a gap between the magled and the aluminium wall where the magled sits in the flashlight. Since air is not a very good thermal conductor I decided to generously cover the magled with thermal paste before putting it back in. Thermal paste/grease is used alot in computers for attaching heatsinks to processors. It fills the gap between two peices of metal and helps transfer heat more effectively. You can buy it at computer stores or even radio shack.
So I've done this and put the light back together. It's been sitting here running for about 25 minutes and it looks *to me* like there has been no drop it output. I took off the head and felt around, the retention device for the bulb(led) is REALLY hot. That is a good sign, heat is being transfered.
I'm not sure if anyone has done this before or if it even helps but maybe someone will try it out and record the results more scientifically. Perhaps it may be possible to add some more metal to the screw on retention peice that holds the LED in, resulting in more surface area and better cooling.
Just some ideas if anyone wants to experiment.
-tibim
-tibim
