Oct 11, 2006 #1 3 3mw Newly Enlightened Joined Aug 11, 2006 Messages 76 Can you guys tell me how they compare? Info like output, throw, size, runtime, quality, etc. Does the Maxfire use a replacement bulb or lamp assembly? Thanks. Last edited: Oct 12, 2006
Oct 12, 2006 #2 I InfidelCastro Banned Joined Jun 23, 2003 Messages 2,266 Location USA Re: Brinkmann Maxfire / 3 Watt Um, are you referring to the LED 3 Watt? In that case it doesn't have a bulb.
Oct 12, 2006 #3 3 3mw Newly Enlightened Joined Aug 11, 2006 Messages 76 Re: Brinkmann Maxfire / 3 Watt Yes, I realize that the 3 Watt LED does not need use a bulb, I was referring to the Maxfire Xenon model.
Oct 12, 2006 #4 gl22man Enlightened Joined Nov 20, 2004 Messages 259 Location Warren, MI. Re: Brinkmann Maxfire / 3 Watt as a matter of fact i don't even think it has a 3 watt i believe it is only rated a 1 watt. But then again i have been wrong before Mike..
Oct 12, 2006 #5 I InfidelCastro Banned Joined Jun 23, 2003 Messages 2,266 Location USA Re: Brinkmann Maxfire / 3 Watt gl22man said: as a matter of fact i don't even think it has a 3 watt i believe it is only rated a 1 watt. But then again i have been wrong before Mike.. Click to expand... There is a 3 watt Brinkmann LED as well. It's about ten bucks more than the 1 watt at Target. To the threadstarter, you might be able to find this info out on flashlightreviews.com I don't really recommend lights above 1 watt that use 3 AAA batteries though. I don't even like the 1 watters that do. Triple A batteries are a poor source of energy for higher powered LED's.
Oct 12, 2006 #6 3 3mw Newly Enlightened Joined Aug 11, 2006 Messages 76 Anybody else? Does Brinkmann use glass or plastic lenses on these models?
Oct 12, 2006 #7 I InfidelCastro Banned Joined Jun 23, 2003 Messages 2,266 Location USA The xenon Maxfire uses glass. I don't know about the LED ones, but I would guess the same.
