I just bought the 1W 3AAA TaskForce light. It came bundled with one of the TaskForce keychain lights ... both (with batteries) for under $12. For that price, I just couldn't pass them up.
The light does flicker a bit ... but I minimized this by lubing the threads and o-rings with a Krytox grease. I could easily get the pieces tight ... but not overly tight.
Craftsmanship is just so-so at best. The finish is bright aluminum ... not sure if it is raw aluminum or if there is some sort of anodizing or other protective finish on the outside.
With the light working consistently, I'm very impressed with it. The 1 Watt Luxeon is bright, smooth has a nice spot pattern (heave ho!) with some usable spill.
But the
lack of blue tint is simply amazing ... it's almost like an incan!
As for the keychain light, it's just so-so. Not as bright as a Dorcy 1AAA but bluer. More compact, but half again heavier. I really like the feel of the little side clickie switch but it can turn on while it's in your pocket and you may not catch this for some time. It takes 3 button batteries.
Is that a flashlight in your pocket, or are you just glad to see me?
