I don't have much time to talk about this right now but I thought this might be of interest (KL6 courtesy of : )> though he doesn't know it at the time of this posting. Thanks Bill ) :
This is a Cree XR-E in a KL6 host. Based on Cree's spec, the LED should put out about 140 lumens at 700mA. I can't get a good beamshot since this is a temporary mount and I need four hands to do the beam shot. The deep reflector does a decent job of managing the Cree's beam profile. The only drawback is that the hot spot is pretty small but the spill is quite wide. I can't get over how bright the Cree is, it just blows away U bin Lux III's at 700mA and the S bin Lux I's at 350-500mA. I won't even mention the K2's--they're not in the same league at all (unless you live up north and want some light with your heat :nana: )
Here's a comparison shot against a UWOJ lux III behind a IMS 27mm reflector
Cree on the left, U bin behind a IMS27 reflector on right. Both LED's biased at 700mA. Lux reading of 6840 lux vs 9400 lux (don't get too caught up in the lux comparison since the KL6 has a different and bigger reflector)
Using a ceiling bounce test (a better measure of total output), the P2 bin Cree measures about 13% brighter. This is consistent with the Cree bin that I have which is mediocre. P4's should be a bit brighter and I expect some P4's in a week or so.
This is the measurement that confirms what my eye sees when switching back and forth between the U bin Lux III and the Cree.
