yuandrew
I'm thinking of something about the size of a stick of gum running on two AAAs or maybe button cells with a regulator circuit and either a momentary push button or a small slide switch that I can EDC on a keychain. LED would be a Luxeon 1 or 3.
As an experiment, I rigged some CR2016 coin cells to a 2D MagLED module and although it wasn't as bright as 2D cells; it was bright enough for some good use if you don't mind the flood type beam.
My idea sprung up for a Keychain type light.
