Ordered a ULTRAFIRE WF602A1 single AA from FIFTHUNIT.COM on Oct 5th. Got it yesterday. Took it apart and noticed it was different from the one I got from QUALITY CHINA GOODS about a month ago. The switch is completely different. Looks like a different switch and lock ring that holds it in. Looked at the LED end and noticed alot more solder there than usual. So I decided to do a run time test to see if failed to come on when the battery dropped to 1.2 volts. Turned it on for 15 min on,15 min off till I had a total of 1 hour of burn time. Still worked great. Still very bright(Brighter than my Nuwai x-1 and My Huntlight FTA2). Got up this morning and ran it for 30 min and turned it off for 5min. It still came back on. Its probably dropped to about 60% brightness now. Left it off for an hour and turned it on for another 30 min. Its still came back on after a 5 min rest. probably about 50 % brightness now. So thats 2 hours of run time with no problems at all. No flickering,no dimming and still comes back on. Im going to order a couple of more and hope they are the same. Maybe ULTRAFIRE has finally got it right.
BATTERY WAS A DURACELL ULTRA.
