Ok, this is the last of my runtimes tests on these three lights. The last light tested is the Luxogen LR5-3W. I used a new Energizer CR123A battery that tested 100% capacity and 2.86 VDC on my Ansmann tester. The ambient room temperature was 74 degrees Fahrenheit.
Start time Lux Output Temperature
10:50 33,700 74F
10:55 33,200 98F
11:00 33,900 114F
11:05 34,100 124F
11:10 34,100 128F
11:15 33,800 133F
11:20 33,600 134F
11:25 33,400 135F
11:30 33,100 136F
11:35 32,800 136F
11:40 32,300 136F
11:45 32,200 136F
11:50 31,900 138F
11:55 31,500 138F
12:00 31,500 138F
12:05 30,600 138F
12:10 30,300 138F
12:15 29,700 138F
12:20 29,200 138F
12:25 28,100 138F
12:30 26,900 135F
12:35 23,800 133F
12:40 18,400 127F
12:45 13,300 126F
12:50 9,220 122F
12:55 7,600 118F
13:00 6,400 114F
13:10 1,800 92F
13:25 1,280 88F
13:30 1,100 85F
13:35 967 81F
13:40 915 80F
13:45 874 78F
13:50 824 77F
13:55 765 75F
14:00 735 75F
The test was stopped at this point. The Luxogen was still putting out light that would be useable in a dark room to light up objects a few feet away. The final voltage on the battery was 1.2 VDC using a multimeter; the Ansmann would not register the battery as functioning. All lux readings were taken at a fixed 10 cm distance and I did my best to thermally isolate the flashlight from the surroundings. It was interesting to note that the lux readings actually went up after about ten minutes into the test. Perhaps the circuit worked better as it warmed up a bit, but I can't say for sure.
The runtime on this light was considerably longer than either of the CR2 powered lights, but this is due to the smaller capacity of the CR2 cell as compared to a CR123A. I also contribute it to the fact I used a rechargeable RCR2 battery for the Smartfire and F&L light tests. Once I get some more CR2 batteries, I may try the runtime again for the Smartfire and F&L, but I don't imagine the runtime would be anywhere near as long as with the Luxogen.
With intermittent use, the F&L J1 or the Smartfire B-13W would serve well and tucks easily inside my jeans pocket without being annoying. For times when you know you will need the light on longer, the Luxogen LR5-3W would be the better choice.
