Oct 16, 2006 #1 E etc Flashlight Enthusiast Joined Dec 19, 2004 Messages 5,777 Location Northern Virginia Is there a kit where you can convert a Mini MagLite, the old Incan version into UV LED? Ideally 380nm?
Oct 16, 2006 #2 J jdriller Flashlight Enthusiast Joined Feb 9, 2003 Messages 1,059 Location New York A quick mod is to stick a 5mm UV led into the MM. (You have to enlarge the hole in the reflector a little)
Oct 16, 2006 #3 F fnmag Flashlight Enthusiast Joined Sep 2, 2006 Messages 2,092 Location Desert Southwest TerraLUX TLE-V is a UV drop in that works real good in the MM. I use it often to rid the Southwest of Scorpions. :rock:
Oct 17, 2006 #4 E etc Flashlight Enthusiast Joined Dec 19, 2004 Messages 5,777 Location Northern Virginia Where do you get it, and what's the nm?
Oct 17, 2006 #5 BVH Flashaholic CPF Supporter Joined Sep 25, 2004 Messages 7,023 Location CentCalCoast A quick search turned up this at luxeonstar.com TerraLUX TLE-4UV (MiniStar1) Worlds's first UV-A LED upgrade kit. It includes 4 395nm UV LEDs that produce 40 mW of UV-A light. Looks like the -5UV is also 395 NM and is 1 Watt Last edited: Oct 17, 2006
Oct 22, 2006 #6 Q quokked Enlightened Joined Sep 20, 2005 Messages 498 $28.95 from http://www.led-replacement.com/tle-5uv.html
Oct 22, 2006 #7 F fnmag Flashlight Enthusiast Joined Sep 2, 2006 Messages 2,092 Location Desert Southwest Got mine from Battery Junction, smooth sale.
