idukhunt said:
How do you get rid of the holes & imperfections in the beam of the mag light 3d cell? I realy like to buy a surefire or something like it, but I need the long run time 3hrs or so. I need a bright light, good beam(no holes) & long run time.Does any body make a light similar to the mag but with a better beam? Thanks for any info.
Welcome to CPF, idukhunt! :wave:
As to your first question, you could probably apply a diffuser of some sort (like the Glad 'Press and Seal' film) but the results are far from adequate on most lights.
Since you are mentioning 'holes & imperfections' I'm going to assume that you are looking for 'flood' over 'throw'. That is, you want broad short-range illumination as opposed to a long distance spotlight. (Mags are already pretty good at this for what they are, and there aren't really any holes if you use maximum focus.)
If you are looking for flood and long runtime, you might want to consider a 3AA MiniMag LED for about $28. According to FlashlightReviews, the light will run just short of three hours to 50% output. You can read the
review here.
It might be a cheap answer to your question, as it's overall output beats the 3D Mag. The throw won't be as good, but it would be considerably lighter and easier to carry. They are somewhat focusable, with no holes. A couple of rings maybe, but no holes.
If you are looking for a better quality beam, you should probably consider a Surefire 5 watt LED based light (if my 'flood' assumption is correct.) can't beat 'em for quality, but the runtime requirement might be a problem.
Just a thought tho'. :thinking:
