LED conversion for Falcata
Phil_B
Near Beverley,Yorkshire ,UK.
I just installed a BOGUSA drop in into my 6V Falcata. It's the one designed for the SF 6P etc.
Easy job. Just remove the standard light assembly, and take the top hat spacer off the spring on the "drop in" module. File this down or spin it in a lathe and file it, till it drops in the hole for it in the body of the torch.
Re-install on the spring, and drop the "drop in" in.
Works first time. Takes ten minutes.
I now have a form factor I love, hefty build quality, and a long lasting whiter (bluer!) light.
Also the Falcata has one of the nicest clickies in the shop. :-D
cancow
Do you lose any brightness with that conversion? I have the Falcata and it is amazing! I a supprised how few people here have one. Where did you get the parts for the conversion? Thanks
