ArmyTek
Results 1 to 17 of 17
Thread: Cool little Finger Light at Walmart
    Default Cool little Finger Light at Walmart
    I was checking out the new local Walmart today and saw something called the "Finger Light" at one of the check out isles. It has a blue LED and a little piece of velcro that goes around your finger and it can be adjusted for wear on any part of the finger. The blue LED is very bright! It has a spot beam because the LED sits in the head of the light and only the tip of the LED is exposed slightly. It runs on 3 very small coin cells that can be replaced if you open up a small screw on the underside of the light.
    I have no clue about the runtime, but for under $2 this little guy is pretty neat and has a nice bright beam.
    Flashaholic* srvctec's Avatar
    Feb 2005
    Central Kansas, USA
    Default Re: Cool little Finger Light at Walmart
    I think they had these a year ago around Halloween as well. I seem to remember some threads here on CPF about them, although I never found any at my local Walmart. I'm going to have to try and find them again.
    Nov 2004
    Atlanta, Ga.
    Do they come in white? if they did, it'd be excellent for map reading at night. The blue tends to wash out the colors so they all blend in.
    - EL Pentalux - Inova T2 - ROP 3D - SF E2e - Fenix P1 - Fenix L2T - Fenix LOD CE - ML1 - D-mini - Malkoff Devices 2D - EL QSP (finally arrived) -
    Wal-Mart seems to have LED lights scattered about the store.
    In the lightbulb section I saw an LED light that clips onto the top of books for reading, and in the automotive section I saw a light that attaches to your seatbelt for pretty much the same purposes.
    Quote Originally Posted by Alin10123
    I don't think so. I looked for white and red LED's, but they only had blue.
    I have the version that is on-off,but just picked up what looks like the same light,but has a flashing mode also. On steady-fast strobe-slow strobe. Got it at Wal-mart a week ago. Have to return it DOA out of pkg. Just all blue leds from what I see.
    I got these Finger Lights at Walmart last year.
    Flashaholic* thezman's Avatar
    Dec 2005
    PA
    Can you get to the led?
    Are they moddable?
    Yep that's them. I think they are pretty cool considering how much they cost.
    *Flashaholic*
    Dec 2003
    USA
    Mut just gave me one of those in white led.
    sure would have came in handy when working on my cummins turbo diesel the other night. tight blind spot headlamp would not reach, but a light attached to fingers would.
    Quote Originally Posted by thezman
    Are they moddable?
    I think I read that the halves maybe glued together. Also somebody has changed out the led.
    Dec 2005
    PA
    Quote Originally Posted by ernsanada
    I keep forgeting what I'm like and the things I"ll try.
    My motto: Everything is moddable.
    Flashaholic* nikon's Avatar
    Mar 2004
    Another time, another place.
    It's true, everything is moddable. Here's the world's first Luxeon disposable firelight.
    Want to buy Tektite and Tekna lights and parts. PM me with what you have.
    Where can I find those in Walmart? I looked all over. Would love to try and mod one.
    May 2007
    Wisconsin
    Quote Originally Posted by boonsht View Post
    Look by the checkouts. I had one, tried to mod it but ended up breaking the case.
    What kind of self respecting nocturnal being cannot see in the dark, one way or another?
    I found those finger lights during Halloween.
    Flashaholic* half-watt's Avatar
    Jul 2007
    Southern Connecticut
    a more expensive military finger lite can be found at BrightGuy.com.
    it's called the Millite Finger Light and is currently pictured on their main webpage.
