Germ
I just got the civilian version of the P90 submachine gun. You know, the one they use on Stargate with the 50 round magazine
The stock optical sight is hard to use if your outdoors in the shade or indoors under normal lighting conditions.
Some folks on the fiveseven forum are adding a light to the sight to help use the sight in these situations. You can check that out here:
http://fivesevenforum.com/forums/showthread.php?t=3166
I've stumbled upon some archery sight lights that look ideal for this. They are tiny and have adjustable brightness (a must), but they only come with blue or violet LED's (I want red). I contacted Truglo and PSE archery and they say red is not possible. Here is the Truglo light, the Tru-Lite Xtreme:
http://www.truglo.com/content/prod_archery_sights_pins/tru_lite_xtreme.asp
Can anyone suggest a similar light in red? How hard would it be to change the LED?
I tried a Photon Freedom light. Unfortunately, due to space considerations I'd probably have to use a fiber optic cable to get the light where it needs to go. Can anyone suggest a good site for learning about using fiber optics?
Here is the Photon on the rifle. The light can't go here because it will interfere with a sling mount:
Any other ideas or suggestions would be appreciated.
