If your powering the ROP LOW bulb you would likely flash the bulb with 8 cells.bxstylez said:whoa!
nice output......... i finally did a ROP mod!
i'm using 7aa alkalines, and 1 dummy spacer
b/c i heard thats recommended
should i go ahead and add the extra aa, making it 8
or will it blow the bulb?
And what would the cost of the quad bored host plus a AWR regulator come to delivered?NikolaTesla said:Flash the bulb? Get 8 cell unit 4 boared and AWR regulator. No Flashing or dimming. Ever. Recharchable. PERFECT white color till beams snaps off when regulator cuts off battery to protect it. Lights that dim get yellolw then brown and die slowly. Obsolete. Bulb NEVER Flashes cuz regulator limits startup surge....
