looman
Just a quick hello to the forum members.
Just acquired a Surefire U2 and like it (thou a little pricey !!!!).
Love all things in the lighting field and look forward to learning lots about the different sources of lighting and power solututions.
I use the the light for 2 reasons
Firstly I am a hunter and whilst I have a deicated rifle mounted lamp with variable power, I find the size is intrusive and as it driving a 50 watt halogen, the battery is a pain on the hip. The wiring can also be a pig when getting in and out of vehicles or if you have to put the rifle down etc.
The second reason is I love gadgets (that work) so do I really need to say more than that. Maybe it should really be reason number one.
I would also like to thank Cone for some initial help re lighting and the like - thanks Mark.
I think the first step is going to be to wean this great little light off the expendable 123's as they are damned expensive in the UK to say the least. I know I can buy in bulk but I use the lamp practically every day and even at a couple of quid a pop - that a lot of wonga plus a lot of waste for disposal too.
I suppose I only have one burning query and that would be to be how feasible it would be to build a small, adjustable power output lamp head onto a rifle but store the battery pack in the butt of the rifle.
It would need to be variable output (which is why I went for the U2 as a first time buy) but the ability to have a small but powerul beam (wide'ish field of view) would be cracking. For hunting a wider beam is helpful in case the quarry exits stage left - so hunting with a tight pencil beam would not be good.
Look forward to contributing to the forum,
Simon
Simon
