What happened part II ?!
tkl
Tx
ok, now when i open a new window it opens up to cover about %70 of the screen. not %100 like it used to. what did i do now?
Empath
Oregon
If you're running a wheel mouse, hold down the Ctrl key while you scroll the wheel.
tkl
Tx
<font size="2" face="Verdana, Arial">that just changes the type size.
B@rt
Land of Tulips and Philips
Try to adjust the size by dragging a corner, and make sure you close it last... This should do it... When opening another IE-window, it should remember the last window size...
Hope this helps,
x-ray
London
<font size="2" face="Verdana, Arial">Edited to correct mistake
1. Adjust the window to the size you want it.
2. While holding down the Shift key close the window.
All windows should now open in the size you just set.
tkl
Tx
still doesn't work, i tried both. it only happens when i try to open a link from email notification from cpf when someone's replied to a thread i'm subscribed.
x-ray
London
Does it happen on all links ? (try clicking on B@arts rainbow above)
x-ray
London
I think I made a mistake in my earlier post, try holding down only the shift key (not CTRL).
tkl
Tx
thanks for the help guys, i'm off to work so i'll try any more suggestions when i get home.
x-ray
London
Just found the following info on Microsoft Technet:
Most problems with Internet Explorer window size can be shaken loose using a Registry tweak. Launch REGEDIT and navigate to HKEY_ CURRENT_USER\Software\Microsoft \Internet Explorer\Main. In the right-hand pane, locate and delete the value Window_Placement. Deleting this value is harmless, as it will be re-created when needed.
You can also set the size for secondary browser windows--the ones you get when you right-click a link and choose Open in new window. Just open a secondary window, size it as you please, and hold the Shift key down while clicking the window's Close button.
tkl
Tx
i tried the shift key and nothing.
x-ray, i don't understand a thing about the first fix.
x-ray
London
If your not familiar with editing your registry, I wouldn't recommend you attempt that fix. Too easy to cause bigger problems
x-ray
London
ok I did a little more searching and found this method:
Open IE and right click any URL that will give you the 'Open in New Window' option
and open it. Now close the first IE window that was open. Now drag the borders of
the second window to fill the screen (Do not use the maximize button). Now hold the
'CTRL' key and click the 'X' to close the window. All IE windows should now open
to this setting.
I just tried the above and it worked for me.
Good Luck
tkl
Tx
to this setting.
Good Luck
<font size="2" face="Verdana, Arial">woooo hooooooo!
mucho thanks, it worked.
