Luxeon Heat? Really?
philamint
I've had a couple of white Luxeon 1 stars running at 300ma for the past few days and really, these things don't put out the heat that I thought they would. I have just a small 1" square aluminum heatsink behind each with a some grease.
They're not even warm to the touch.
From what I gathered with the posts here, I had anticipated more of heat generated.
Could anyone confirm?
havand
Pa, U.S.
300ma is pretty low. I flicked a light of mine on the otherday while walking to keep my hands warm. Draws something like 1.4A from the battery...Most of that is going to the LED. Oh yeah, there's heat ;) There is more at drive level and beyond. At lower current levels, they're more efficient.
amanichen
Virginia
1. Heat output will vary depending on what current the LED is driven at.
2. Open air on an aluminum heatsink with thermal grease is a much better cooling method than stuffing it inside the head of a light. Therefore, in your testing, the temperature of the emitter will be much lower than when installed in a flashlight. The same emitter might get much hotter inside of a light, which gives people a false sense that it's somehow producing more heat. This leads me into the next point...
3. Heat transfer is not equal to temperature. A difference in temperature causes heat transfer. Thus, the "hand tests" that people perform by touching the body of their light and saying "ouch!" or "hey that's cool" mean squat. You need to look at the temperature distribution between the heat source and the heat sink, and know the thermal resistances, to calculate heat production of the emitter.
philamint
300 ma is low? Maybe I misread but I thought the Luxeon maximum was 325ma or so?
amanichen
Virginia
There are different Luxeon series, based around different die designs, and within each series, there are multiple bins used to account for the variations due to manufacturing.
You can always overdrive or underdrive a LED, but overdriving will reduce the lifespan.
Lite_me
Northern OH
This might be better ask in a different forum but it is in keeping with the subject header.
If I wanted to use an LED flashlight for a hand warmer, how much energy is lost to light? As a hand warmer, would it be inefficient? :thinking:
havand
Pa, U.S.
Who needs light? Just put a resistance coil in the end of it with a variable current switch :p
billw
SF Bay Area
My ROUGH interpretation of specs was that at 1W in open air, you didn't need much more than the "STAR" as heatsink. The 3W and 5W need more, and you have to pay
some attention if you're going to seal up the star (or an emitter) inside a flashlight body.
(and cooler is better. Who makes an LED flashlight with a fan? :)
