Kryosphinx
I got this out of some old junky twist for lantern/flashlight.
Here are several thousand words.
It's the reflector on the right.
The only two lights I was able to try it with were Arcmania's Soli Drop-in and my Mag11, because those are the only two lights that have the focal point high enough for the reflector. It focused the soli quite well. It threw a spot about 5in in diameter at 13ft. Stock mag reflector was close to that, but a tad bigger. With the Mag11, it ROCKED. Beautiful beam, but since the reflector's made of plastic, I'm to scared to run it for more than one second at a time. It is very similar to Fivemega's deep reflector, but more floody. Throws similar to Litho's SMO reflector, but with a perfectly circular beam.
I don't know what to do with it. Perhaps a Cree XR-E would work with this, due to the depth/width ratio being so high.
