D@rk Messenger
Technically speaking, you can run the low at a much lower brightness and since they would be underdriven that way, have a much much better tint, and they would last much longer as well. Is there a reason besides perhaps prohibitive cost, and perhaps higher current being used? I know that the fenix lop-se can run on low for about 8 hours to 50%, and still be reasonably bright compared to most 5mms, only with a much better tint, as well as the ability to use higher voltages for bright light for multi tasking. Any reasons why? I would really like to see a production model of an arc with similar capabilities using a luxIII or cree xre lamp( if the cree works out).
