NightShift
I have a bunch of bright red LED's - about 60 - from a brake light. From this I wanted to make small clusters out of them for other purposes such as retrofitting brake lights, so I ended up breaking the circuit board and gluing them together to make a cluster, then mending the circuit to work right. The way im doing it is messy and flimsy and it would be great to design my own circuit board at home - to mount the LEDs on a sturdy surface and have a solid, evenly spaced cluster construction....
Is this easy to do?
If it is, could someone tell what it involves and the things I would need from RadioShack, if they are available there? If it is simple and cheap, im sure it would be fun doing.
Thanks
Is this easy to do?
Thanks
