I bought a bunch of these white LEDs, intending to use them as indoor lighting in a motorhome. Result? Far too dim!
Some time later, I bought a 'Tru-Forge' flashlight with 9 white LEDs from a dollar store. (Cost, $1, no sales tax in Oregon.
) It runs the LEDs in parallel, unregulated by any means, off three AAA alkaline cells in series. Quite bright with a defined hotspot in spite of no optics other than a flat piece of clear plastic.
Then an idea hit me... "What if I replaced those LEDs with nine of these HK ones and forget the resistors?". The cheapie light went from bright to do not look into light with remaining eye! No hotspot at all, just a well diffused shine that casts hard edged shadows on the far side of a room. I've run the thing for long periods of time and it doesn't get the least bit warm, unlike the 12 and 28 white LED flashlights I have from U-Lighting America. (To my eyes, the upgraded cheapie equals the 12 LED one and comes close to matching the 28, even though all three use the same 3 AAA unregulated power source.)
So, now the backstory is told, what sort of a driver would duplicate the voltage and current of three AAA cells from 12 volts in an automotive application? Or would a PWM or other pulsing type driver work better? I'd prefer a circuit with the LEDs in parallel so I can use the circuit boards from the $1 flashlights, but other configurations will do as well.
Whatever can pump the same brightness out of 9 of these LEDs, I DON'T NEED dimming control or any other sort of adjustability. I just want to put the LEDs and drivers into the light fixtures in the motorhome and use the power switches already on the fixtures.
This image is the first part out of the mold I made for an LED holder. The LEDs are the originals on the PCB from a $1 flashlight. It's red because this one and casting #2 will be used for running lights on a street rod, with red plastic cast over the LEDs.
I'm hoping I can assemble driver electronics small enough to fit in the back cavity so that can also be potted and just have a pair of terminals poking out. I'll be making this same holder in clear for the lights in the motorhome.
