nuggett What cells are you using?
I take it you are using 2xrcr123 unprotected.
It would be nice to run this mod on protected cells, but I'm guessing it may need a double tap to start it. I think the current draw on the TL3 lamp is around 1.25, so I'm guessing around the 30 minute mark on rechargable cells.
I have been planning to do this for a good while now, I have the lamp holder, but lighthound is out of Tl3 lamps. I was hoping the new batterystation protected rechargable cells may have protection cuircuits that can handle this without the need to double tap.
I will wait and see when lighthound gets the Tl3 lamps back in
How is the beam, you say "Auroralites Mag hotwire mod has a much nicer beam", is there a problem focusing this lamp in the stiron mod base? I had hoped it would be wide and floddy rather than a thrower, as I'd prefer a nice wide spill / wide hot spot in an E2D for close up work.
