A while back I had a pair of little blue LED disposable clip on lights that were bright enough to see with but had a very narrow hot spot with a wide dark ring and a fairly decent illumination outside the ring.
So, just for a lark, I took a file and flattened off the dome completely on one. It then produced a broad but nearly completely even field of light.
I'm thinking of doing that to the center LED in the 9 white LED RV modules I'm going to make.
Think it'd help make for a better light to see by? the whole thing will be inside one of those typical 5" square 12V overhead mounted fixtures with a frosted/bumpy diffuser lens.
