woodrow
I had been using energizer lithiums in my MMag 3aa light, when I saw a graph showing 2600mah rechargables would give the same runtime. I went out and bought 4 2500mah (energizer) batts and a slow charger (all in one package) for around $20 at Target.
I charged the batteries and everything worked great... the first night. When the beam became dim I threw the 3 batts on the charger leaving the 4th unused battery's spot empty. The beam started out bright but dimmed within 30 minutes. I had thrown away the instructions (put batts in the right direction seemed pretty simple to me) but thought that I must need to charge all 4 batts at once or the 3rd batt would not charge. I knew that I could charge only 2 batts in the charger from the instructions. Again...4 batteries-1 unused-3 very low were charged until the light went off on the charger. Again, dimming after 30 min.
I emailed energizer and they said their charger could charge 2 or 4 batts only. My belief is that unless all 4 are = dead, it will stop charging when it senses the full battery.
Can anyone recomend a charger that can do 3 and only 3 AA's? Any help would be greatly appreciated.
