Hi there, just a quick question. when I'm setting up my
external pot for a Fatman, do I use the poles on the pot that allow max resistance when turning counter clockwise or clockwise. The instuctions say to " hook up the ext. pot.. dial it to max resistance and then set the trimpot using an ohm meter to the max value you want" I want full brightness when turning clockwise, so would max resistance be in the zero position or the full right position? I'm confused?:huh2: Hope this makes any sense!
thanks,
thanks,
