PeterScowcroft
- Joined
- Oct 1, 2006
- Messages
- 73
Hi,
I have (mostly) built a headtorch running 3 Kree XR-Es, and a buck driver with efficiency of above 85% from 11AA cells at 1.3v each (average) and a capacity of 2700mAh. Everything is in series.
I will be running the XR-Es at 0.72W, 1.36W & 3.04W.
Does anyone know how I could derive the expected length that flashlight would run before the batteries died?
I work it out that it should last at least 14hrs at .72W; 7.4 hours at 1.36W and 3.3 hours at 3W respectively.
Can anyone confirm that this sounds correct, or even better show me how to calculate the exact figure?
Thanks,
Peter.
p.s. I will even show the first teasr shot of the torch for the first good answer!
Thanks,
Peter.
